ABS failure XK8 1999
Old Sep 28, 2008 | 03:14 PM
Gus's Avatar
Gus
Default RE: ABS failure XK8 1999
I found at times that improper tire pressure would cause the car to feel a bit out of alignment. I would check that first before going for an alignment. As for the ABS I had a problem with mine and had to replace the ABS control. If I were you I would check your sensors to see that they are clean first and also see if you set an OBD code before spending any time and money. I have heard of people having the ABS control rebuilt. However, I have no ides if it is worth the effort. Good Luck!
Old Sep 29, 2008 | 10:24 AM
dugem260's Avatar
I also had the misfortune of replacing the Brake control module (more than $2k). Hopefully it is just a cable between the sensor & the module which will be closer to $100. These electrical issues are not likely to be related to an alignment issue.
Just keep thinking how beautiful the car is and you'll get the kinks out eventually...
Doug 2001 KKR convertible
99xk8guy
May 28, 2024 09:36 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Oct 12, 2015 11:56 AM
John Fox
Sep 19, 2015 07:56 PM
mrobinson
Sep 18, 2015 07:20 AM
