ABS failure XK8 1999
Old Sep 28, 2008 | 03:09 PM
badmojo's Avatar
Default RE: ABS failure XK8 1999
I get that fault occasionally also and it goes out after restart. Usually it's just some dirt or debris temporarily blocking one of the ABS sensors. As long as it goes out It should be OK. Now do mean that the car pulls to the left or right ? Also is it the left or the right or both? Again mine also pulls slightly to the left but more so if the road has a little crown to it. I would start with an alignment.
Hope this helps!
Old Sep 28, 2008 | 08:45 PM
badmojo's Avatar
I would have it checked to see if there any worn or loose front end parts (suspension or steering). The alignment shop should be able to tell you.
Old Sep 29, 2008 | 12:31 AM
H20boy's Avatar
I recall a post awhile back about a 'wandering' jag, and was suggested it could be extremely worn bushings on something, cant recall what. Had to do with the steering components I believe. Maybe jag_genious will drop by and fill in the blanks. I think he was in on the diagnosis.
99xk8guy
May 28, 2024 09:36 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Oct 12, 2015 11:56 AM
John Fox
Sep 19, 2015 07:56 PM
mrobinson
Sep 18, 2015 07:20 AM
