abs light on
Old May 26, 2009 | 11:06 AM
jaysto's Avatar
Question abs light on
just started car and ABS light is on and a message saying traction not available ,can anybody offer any help ......2001 xkr 4.0
Old May 26, 2009 | 10:40 PM
kntjafo's Avatar
Default abs light on
I had the same problem with my 05 XK8. Dealer replaced a control cable, which took 8 weeks to get. Under warranty. No idea of the cost. Light will still come on at times, as with most "caution" messages in the Jaguar, I tend to ignore them. Having owned Jaguars and British cars for more than 40 years, I expect false readings from time to time. If it is not something like a hight temp, or oil light I tend to monitor the situation and not get too concerned.
Butch
Twentynine Palms, CA
Old May 27, 2009 | 01:17 AM
H20boy's Avatar
could be a few things jaysto, i'd try these in this order...to see if it clears your MIL
If you could get your ABS codes read, you could at least tell which wheel was affected. Since you don't...
(1) clean all the wheel sensors with dish detergent really well, brake dust accumulates and causes havoc...this fixed my intermittent traction control message
(2) wiring harness to wheel sensor
(3) wheel sensor - you could swap side to side, but you gotta check the code on an OBDII reader to see if you're making any headway or not
(4) abs module, doesn't happen alot, but has been a few that I have heard of
(abs
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
