ABS Light Staying on
Old Oct 18, 2013 | 09:14 AM
Burdedw's Avatar
Unhappy ABS Light Staying on
My friend Lance has 2 Jag's, a 1998 XK8 and a 1998 XJ8.
He has been having an issue with the ABS light on the XJ8 and took one of the Speed Sensors from his XK8 to verify the problem.
Now the new problem is that when he put the good Speed Sensor back on the XK8, he had the key on and the ABS Light is now on all the time,
Do any of you know how to get the light off?
Thanks, Dave B.
1998 XK8
Old Oct 18, 2013 | 01:11 PM
RJ237's Avatar
My experience has been that the light will go out on it's own after a few hundred feet. It is possible that the wire inside the cable was ready to fail due to flexing and he broke it. But try a hard reset. Disconnect the negative battery cable and touch it to the positive terminal. This allows the capacitors in the modules to discharge and start from zero.
Old Oct 18, 2013 | 03:06 PM
Burdedw's Avatar
RJ237, Thanks so much... we drove the car and sure enough in about 100' the light went out. Happy Camper.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
innzane
Sep 2, 2015 10:08 AM
