abs problem
Old Nov 18, 2012 | 09:16 PM
john henderson's Avatar
Default abs problem
i recently developed a problem. after 10-20 mins. driving i get a sensation like an unbalanced wheel, can be light or pronounced. slight shake in steering wheel, persists at low speed, i can feel it in the brake pedal. settles when car parked and cooled off. mechanics first try was to ensure rotor was true and service calipers. he may have said it was localized to one front wheel but i'm not sure. could it be abs sensor, module, pump or something else. any ideas ?
Old Nov 19, 2012 | 07:51 PM
BlackX300VDP's Avatar
Front wheel bearing?
Old Nov 20, 2012 | 05:42 AM
im betting its not a wheel bearing. it only comes on after about 15 min. it is a rythmic pulsing with frequency independent of speed.i may try removing abs fuse.thx.
Old Nov 20, 2012 | 05:58 AM
These things will normally display an ABS light at the slightest provocation.
Could be a brake piston 'grabbing' in the caliper bore when it heats up.
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
pocketrocket
Sep 3, 2015 07:44 PM
laserguy
Sep 3, 2015 02:02 PM
innzane
Sep 2, 2015 10:08 AM
