ABS Ring Tool
Old Nov 13, 2016 | 02:05 PM
RJ237's Avatar
Default ABS Ring Tool
I'm going to have to replace my front bearings soon, and wondering if anyone in the Atlanta area has the tool and is willing to loan or rent it.
Old Nov 13, 2016 | 02:29 PM
RJ - if you can't find a forum member with this - JCNA has a tool loaner program and should be able to assist
Old Nov 13, 2016 | 02:42 PM
avern1's Avatar
Look up Forum member SCARDINI and PM him. He used to have one to loan out for cost of mailing.
Old Nov 13, 2016 | 03:04 PM
RJ237's Avatar
Thanks Vern. The JCNA collection is at Coventry West and I'm a member, but it's fifty miles away and I thought maybe I could find someone closer.
I'm also tempted to take the uprights and bearings to Wizard Automotive here in Douglasville and save myself the aggravation of fighting with the rings and bearings. My car is rust free but I expect the rings will still be hard to break loose.
Old Nov 13, 2016 | 03:07 PM
michaelh's Avatar
RJ,
Just a thought, although I doubt it is a surprise:- Jaguar under-specced our bearings and changed them from 99+
If you can get hold of a pair of hub carriers from a later model cheap* you could refurb and then do a straight swop = less down time?
Mike
*"Glass half full"
Old Nov 13, 2016 | 03:53 PM
Ungn's Avatar
Originally Posted by michaelh
RJ,
Mike
*"Glass half full"
I just Bought a Pair of '01 XJR Spindles/dust shields for $60 total including Tax + core charge at the local Pick N Pull. I have 2 spare ABS sensors, now, too.
$20 more got me the 325mm caliper brackets.
I just did my bearing/brakes a year ago, but likely can't help myself upgrading to 13" brakes, because it was so cheap (and now I have the tool and the press).
Old Nov 13, 2016 | 04:24 PM
michaelh's Avatar
Given that the OEM sensors are north of $200 each I'd be smiling at that particular pull
That will be the path I'll follow when my fronts let go - which they will.
Mike
Old Nov 13, 2016 | 04:51 PM
motorcarman's Avatar
RJ,
Mike
*"Glass half full"
If I had a 1997/98 XK8 I would do the vertical link swap.
bob
Old Nov 13, 2016 | 05:12 PM
michaelh's Avatar
If I had a 1997/98 XK8 I would do the vertical link swap. bob
Oops! That's what I meant.
Thanks for the proper term.
M
Old Nov 13, 2016 | 07:03 PM
RJ237's Avatar
As far as I can tell, my originals lasted 98K mi. My expected use is in the area of 2K mi/yr. and the replacement bearing is a Ford Winstar part costing less than $20 ea.
If I could find a set of later uprights with good bearings for less than $100 I would do so, but my budget is seriously constrained due to dental expenses and I have to take lowest cost route.
I know- sell the Maserati, and I'm considering that, but every time I start the engine...............
Old Nov 13, 2016 | 09:17 PM
Ungn's Avatar
Mike
Well I did have to stop off at Harbor Freight on the way to the junk yard to buy a 4lb hammer to smack the balljoints apart. That was another $10.
There is no more satisfying sound than a balljoint popping loose.
My local yard crushed 3 XJ8's in the last week. If I knew they were going to crush them I would have pulled more parts off of them. The 2002 XJ8 had a lot of good parts left.
