ABS Wheel Speed Sensors
Old Jun 20, 2015 | 07:38 PM
champir's Avatar
Default ABS Wheel Speed Sensors
Hi,
Can anyone tell me what the correct part number is for the ABS Wheel Speed Sensor for a 2003 XKR?
I have had one fail and the replacement item I got from a parts supplier appears physically compatible but electrically they appear to be different.
The original is marked 2r83-2c190-ab / ATS 10.0711-6069.3
Replacement parts supplied are marked LJA2226-AA / ATS 10.0751-1145.3
Although they are physically compatible, I am guessing they are electrically different. The original sensor on another wheel measure 9.1M Ohms resistance
Replacement sensor measures 1.1k Ohms resistance.
By a process of rotating parts between wheels I have concluded it is definitely that the original sensor has failed and that the replacement isn't compatible. I am pretty certain it isn't a wiring faut.
The OBD fault codes involved are C1165 & C1175 (etc) for right-rear and left-rear respectively which change to the location of the new or replacement sensors.
It is actually the 2nd replacement sensor that I have acquired as I thought the first was faulty.
Should the LJA2226-AA part work in my 2003 XKR?
Which vehicles had the 2r83-2c190-ab parts.
Or do I have a bigger ABS problem here?
Thanks,
Rob.
Old Jun 21, 2015 | 06:10 AM
Gibso's Avatar
Hi
I have a 2001 XKR and the sensors are LJA2226 AA. Resistance reads 1.1K.
I have not seen the sensor from your XKR before. 9.1 meg ohms seems very high.
Do your good sensors read 9.1meg ohms?
Old Jun 21, 2015 | 04:09 PM
astromorg's Avatar
The sensors changed from the passive type in pre 2003 XKs (ABS) to the two wire active type in 2003 (DSC). They are not interchangeable ( Which seems to be unknown to some, particularly ebay sellers)
Your first photo shows the later type, the second the earlier. Sorry I don't have the two part numbers!
Old Jun 22, 2015 | 04:20 AM
woox4's Avatar
Looks to be XR822753
XKR 2003 To 2006 From Vin A30645 Front & Rear
Old Dec 9, 2020 | 08:32 PM
zray's Avatar
A reputable vendor, like SNG Barrett, are worth their weigh in gold in situations like this.
Right parts . Every time.
https://www.sngbarratt.com/English/#...Parts/Families
Z
Shinda’s XJR
Mar 28, 2024 07:48 PM
Vee
Nov 24, 2020 07:34 AM
Pantera928
Nov 27, 2017 04:04 PM
butch h
Oct 29, 2016 05:38 AM
JagYi
Nov 5, 2011 12:30 AM
