Accelerator problem
Old Aug 13, 2008 | 08:55 AM
GordoCatCar's Avatar
Default RE: Accelerator problem
I can only suggest the obvious troubleshooting procedures; which any dealer or competent mechanic would check first. Return coil spring, binding in cable, stuck throttle body plate, etc. An air leak somewhere might cause slight increase in rpm. But again, I would think any good mechanic would be on those items.
Also there maybe some causal factorsassociated with the system that controls highidle at startup; but all of that is sensor and ECM controlled, and I do not know how you would check that. The idle control ciruits operate independently of the throttle plate opening.
Finally, make certain your cruise control is OFF.
Otherwise, until there areadditonal details or symptoms, thisis an enigma to me.
toronadomike
Jan 22, 2026 10:13 PM
ajacks86
Oct 12, 2017 08:51 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
jdzubas
Oct 4, 2015 09:14 AM
XFR_Gold
Sep 2, 2015 12:24 PM
