Active Cats Dampening question
Old Aug 24, 2021 | 03:31 AM
2ndeagle's Avatar
Default Active Cats Dampening question
Currently undertaking the upper shock mount replacement along with brake pads/rotors, front and rear.
Is their anything I should be concerned, when removing the upper shock bolt, besides spring compression? The shock electrical connection, inside of the retaining nut, has me at a pause, as it appears the inner connector has an allen/hex shape and I really want this to go as smooth as possible.
Any advise/precautions are deeply appreciated.
Thanks in advance.
Darrin (DT).
Old Aug 24, 2021 | 05:37 PM
baxtor's Avatar
Thanks in advance.
Darrin (DT).
l don't think there is any particular do's or don'ts. The socket head in end of rod is probably more for plug orientation for reconnection. It might be an advantage to use an Allen key to minimise the rod rotating while undoing the top nut but you won't break anything internally if it does turn.
Make sure to correctly orient the top mount and bottom eye before releasing your spring compressor.
Old Aug 24, 2021 | 06:19 PM
2ndeagle's Avatar
Thank you.
With a closer look, I could see the sensor is actually inside the shock rod and not a rotational issue.
Made note of the alignment suggestion.
Robert Grisar
Apr 23, 2018 10:54 AM
mhminnich
Jul 19, 2017 08:58 PM
hawaiianjag
Jul 17, 2014 06:01 AM
theusualsuspect
Jun 6, 2012 11:21 AM
