After Market amp over heating
Old Aug 7, 2012 | 03:14 PM
Jdub's Avatar
ud
Default After Market amp over heating
Hello all, I have a new problem. My alternator went bad and I had it rebuilt by the local electrical shop up the road. I could "hear" it was bad. I got the car back and my voltage is fine but my amps still over heat. I've tried two different ones and I know they both cannot be bad. I've also went over the wiring and made sure my ground wasn't on paint and I still have over heating issues. My voltage doesn't drain when my speakers hit but I have noticed it drop down some when the aux fans come on? Any suggestions? the voltage in the wires going to the amp has been testEd as well and all is ok. Thanks Joel
Ps amp is 15001bd fosgate pushing two jl12w3v3 subs. Have a Hifonics Brutus 16001.d that gets hot as well. Wired for two ohm and both amps are one ohm stable.
Old Aug 7, 2012 | 05:08 PM
itspec60's Avatar
Did you use 4 gauge power and ground wire? I notice that amp is pretty stout. Installation calls for a 200 amp inline fuse. Too light a gauge wire could cause it to overheat.
Old Aug 7, 2012 | 05:17 PM
Jdub's Avatar
ud
No I have a zero gauge from the battery to a 100amp anl fuseblock to an extra optima battery and then I have zero gauge ground for that battery and 4 gauge for the amp. Sorry I forgot to add that. That's why I'm stumped. It's more than enough than it needs because I had this same setup with 4 12s in my Lexus at one ohm. It had a 100 amp alternator too.
Poet
Feb 7, 2025 02:18 PM
Joachim1167
Nov 7, 2020 09:18 PM
n2audio
Oct 1, 2015 01:54 AM
oldjaglover
Sep 29, 2015 03:27 PM
Rocky15
Sep 28, 2015 04:59 PM
