After the tensioners
Old Apr 20, 2015 | 05:26 PM
jetjack's Avatar
Default After the tensioners
Finished my tensioners today, both had cracks about an inch long.
I ordered some new spark plugs, just waiting for those to finish up.
The question is, is it safe to start the engine before the tensioners are filled with oil, or should I crank it some without starting to build up oil pressure?
Thanks!
Jack
Old Apr 20, 2015 | 05:34 PM
DaveInVA's Avatar
It would be a good idea to pull the fuel injection fuse and crank it until oil pressure builds up before starting it.
Dave
Old Apr 21, 2015 | 07:47 AM
mrplow58's Avatar
Mine were both collapsed, when I changed them out, so I started the engine. It quieted down after about a second. Removing the fuse seems like a good idea though......
Old Apr 21, 2015 | 03:35 PM
blindside's Avatar
When I did my tensioners I just turned the car over for a few seconds a couple of times before I put the coil packs back on the plugs... no problems...
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
millertic
Sep 30, 2015 08:11 PM
JAMES1944
Sep 29, 2015 11:58 AM
