Aftermarket driver's seat
Old Feb 1, 2013 | 08:18 PM
jabingb's Avatar
Default Aftermarket driver's seat
I have given up trying to find a drivers side Jag Recaro for my '03 XKR coupe. So, have any of you put some aftermarket seat in your XK8/R that can actually hold oneself in place while driving spiritedly? It doesn't have to be fancy, heated, etc, actually the more manual, the better as I am typically the only person that drives the car.
Old Feb 1, 2013 | 10:14 PM
ccfulton's Avatar
There is at least one forum member who did this and posted about it. Turned out pretty well.
https://www.jaguarforums.com/forum/x...e-seats-71123/
Old Feb 1, 2013 | 11:13 PM
jabingb's Avatar
Charlie, looks like something I might do, thanks for the link!
Old Feb 5, 2013 | 12:26 AM
jabingb's Avatar
Here's my Recaro driver's seat installation that I just completed. It wasn't trivial but will be well worth the effort when I do a track day at Laguna next Monday. I'm getting a CG Lock to hold the lap part of the stock 3 point in place.
Attached Thumbnails Aftermarket driver's seat-recaro1.jpg   Aftermarket driver's seat-recaro2.jpg
Old Feb 5, 2013 | 01:28 PM
Neat.
Did you modify the original slider or replace it?
Old Feb 5, 2013 | 09:28 PM
jabingb's Avatar
Decided to leave the original seat in useable condition so everything is still attached, 4 bolts, 2 connectors and it could be back in. But I doubt it will be anytime soon as the Recaro is so GOOD. One of the bolts would not come out, just spun so I had to drill it out and managed to save most of the threads, grrrrrr. Used a set of Recaro sliders, needed a bit od drilling, good thing I have access to a machine shop.
Old Feb 5, 2013 | 09:46 PM
ccfulton's Avatar
Looks like a nice seat and a good fit.
If you recovered it with a correctly colored leather it would be hard to tell it wasn't supposed to be there.
Old Feb 6, 2013 | 03:38 AM
Originally Posted by jabingb
............... One of the bolts would not come out, just spun so I had to drill it out and managed to save most of the threads, grrrrrr..
Jaguar tend to repeat design ideas across the model range and the XK8/XKR seat fixings are probably the same as the X308.
When I got my X308, the passenger seat runner rear fixing was ripped out through the floor:
I expected the tapping for the fixing bolt to be welded to the floor but it was a substantial spring clip which slid into a slot in the floor. In the above pic the damaged spring fixing is on the left and a replacement with seat bolt sourced from a breaker on the right.
With the replacement slid into position, the seat bolted in perfectly again and I had no more trouble with it.
Next time you have the seat out, it may be worth checking if a simple fix like this can work with the XKR.
Old Feb 6, 2013 | 06:39 AM
Frog's Avatar
If your aim is to take the car on the track, then you made the right choice not going for a Jaguar Recaro seat: they're hopeless and don't really offer much lateral support. Way less, for example, than the standard seats I had on my 2010 VW Golf GTI.
Old Feb 6, 2013 | 09:39 AM
jabingb's Avatar
I looked at it rather carefully although the carpet is wellformed around the attachment point and may well hide such a spring clip. The seat will come out one more time and I'lltake a much close look and a couple pixs. If replaceable I will definitely do that, have even thought abouthelicoil repair as the thread is compromised.
It's at the left front side of the seat, not the back, so a little less critical. The bolts that I removed all had a steep spiral groove though the threads, some form of locking system I presume, but this one spun without any real extraction force, leading me to believe it spun at assembly time, don't think the seat had been out before.
Old May 10, 2014 | 07:57 PM
jabingb's Avatar
The seat worked great but sadly I sold the XKR so I do have the Recaro available to a like minded soul who wants a seat that REALLY holds you in place! One note of caution, narrow hips/waist fit only.
Clamdigger
Sep 12, 2015 03:43 PM
jagent
Sep 12, 2015 09:10 AM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
