Air Bag Light Issues 02 XK8
Old Aug 13, 2008 | 01:41 PM
Metapoint's Avatar
Default Air Bag Light Issues 02 XK8
Working on selling my 2002 XK8 Coupe, have the Air Bag light on. When I start the car the air bag light flashes then stays on. About a month ago it started intermittently where it would come on once every three or four trips. Now its every time I drive the car. Any ideas, anyone had their car into the dealer for the same issue. Anyone have any info on the code flashing, its been sugguested that the number of flashes may indicate what the code number is, but I only have access to Alldata software and it doesn't list anything in the codes section of what the code could be. Hooked the car up to a basic snapon handheld scanner and it shows no codes.
Old Aug 13, 2008 | 02:03 PM
rscultho's Avatar
Default RE: Air Bag Light Issues 02 XK8
Seems that I read about a similar issue not to long ago - that problem was being caused by the weight sensor in the seat(?)...something to that effect
Old Aug 13, 2008 | 10:27 PM
H20boy's Avatar
Yes, you are correct. or I have seen a couple owners that had wires that got pulled from the harness. At least you can visually identify the latter cause...
Jimscriv
Nov 4, 2015 02:18 PM
daro31
Sep 1, 2015 10:24 AM
peterg19
Aug 30, 2015 08:48 AM
Jandreu
Aug 29, 2015 07:31 PM
Chris New
Aug 27, 2015 03:14 PM
