Air Conditioner runs warm
Old Jul 30, 2014 | 01:56 PM
Bond2006's Avatar
Default Air Conditioner runs warm
Got a 2006 XK8 that blows warm air from A/C in park or standing traffic. Immediately the temp gauge starts to rise towards hot. No problem when driving. Fans work properly, new thermostat and water pump. Suggestions or experience?
Old Jul 30, 2014 | 02:04 PM
brgjag's Avatar
did it do this before the new pump/tstat?
Old Jul 30, 2014 | 06:30 PM
Stumpy's Avatar
Might just need refrigerant/gas topping up.
You can try running the Climate control internal diagnostics and see if that gives any answers.
See here for how to and codes:
Old Jul 31, 2014 | 02:30 PM
oldmots's Avatar
More than likley, the fans are not working properly. This symptom is that of a failed cooling fan control module, I know, I just had the same symptoms.
Old Aug 5, 2014 | 12:53 PM
Bond2006's Avatar
Not before the tstat but the water pump was the initial resolution; however, it apparently hasn't solved the issue.
cissdm
May 3, 2016 06:02 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Jjscruggs1
Sep 3, 2015 07:46 PM
XFR_Gold
Sep 2, 2015 12:24 PM
