Airbag B2291
Old Jan 22, 2022 | 10:36 AM
jeffspain's Avatar
Default Airbag B2291
I had the airbag warning light flashing 2-7 code B2291. The local Jag specialist put a replacement passenger occupancy seat sensor in but it still had the error code. He said he thought it might reset itself after a while, and over Christmas it changed to a 1-7 flash code. I took it back to be rescanned (the car can only display one fault at a time). They seemed to think the part they installed hadn't worked and they need to get another one.
Today I had a heavy box on the passenger seat and noticed the Airbag warning light facing the passenger (above the glovebox) came on. This would indicate to me that the occupancy sensor is working as it doesn't come on when the seat is empty. I am thinking the problem may be further down the line. According to the wiring diagram the sensor plugs into a weight sensing module. Does anyone know if these are still made by Jaguar (ford), and do you think this could be the problem?
Thanks for reading to the end. Any suggestions welcomed.
Old Jan 22, 2022 | 12:15 PM
astromorg's Avatar
If you haven't read this TSB http://www.jagrepair.com/images/TSB/...sh%20Codes.pdf you might find it helpful.
One thing to note is that there is no mention of a 2-7 flash code and another is that there are quite a number of SRS faults associated with the 1-7 flash code. To narrow down the 1-7 faults requires the Code PID (No, me neither) but it sounds like it needs an advanced type of scanner to get the full info!
Old Jan 25, 2022 | 10:40 AM
jeffspain's Avatar
Thanks. Thats a useful document. I'll try and find out from the garage what the PID code was.
Old Nov 29, 2022 | 06:29 PM
overpowered's Avatar
Hi,
Would this TSB apply to a 2004 xj8? I have the same dtc
Old Nov 29, 2022 | 07:15 PM
motorcarman's Avatar
You should post your question in the X350 forum section.
Here is the DTC guide for your car.
File Type: pdf
Kiwimike
Nov 17, 2020 06:16 PM
Fauconberg
Aug 1, 2020 02:37 PM
Jon89
Dec 22, 2016 09:12 AM
cyberice
Oct 21, 2014 11:19 PM
monz87
Feb 14, 2011 05:38 PM
