Airbag Warning Light Code?
Old Feb 8, 2015 | 09:27 AM
Fish13's Avatar
Default Airbag Warning Light Code?
Hi,
Yesterday whilst on a long drive my airbag warning light flickered and then flashed and came on full time.
This morning, the sequence of flashes is as follows:
1 flash, then a pause, then 6 flashes in quick succession.
It repeats this cycle 5 times, then stays on permanently.
Can anyone tell me what this means? Is it safe to drive?
It's a 2002 Jaguar XK8 4.0 Coupe.
Any help appreciated!
Cheers,
Fish.
Old Feb 8, 2015 | 09:46 AM
jimbov8's Avatar
. Air Bag 'Flashing' Codes straight from a Jaguar TSB (in pdf) Available to download free at the top of the forum in the stickies.
Check out the codes from the above sheet. Looks like you have a bit of work to do.
Jim
Old Feb 8, 2015 | 10:37 AM
Fish13's Avatar
Thanks Jim,
Code pointed to passenger seat and I just had a look under there with a torch and one of the multi-plugs had come loose, so I pressed it back together and that seems to have fixed it!
Turned off and on 3-4 times and the light now goes out as it should. It must have been knocked loose over time by potholes etc.
Cheers for your help.
Old Feb 8, 2015 | 10:39 AM
jimbov8's Avatar
Well that was easy fix. Glad you're sorted and thanks for the update.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
AL NZ
Sep 4, 2015 08:39 PM
edtexas
Sep 4, 2015 08:20 PM
