The AJ27 ECU
Old Jul 6, 2024 | 10:50 AM
Chirpy's Avatar
Default The AJ27 ECU
Our AJ27 ECU design is now about 25 years old, and the AJ26 even older. As items go obsolete (the Pedal Position Sensor comes to mind – although ASI does a good refurb job at a price), it is probably going to get more challenging to maintain everything. In addition, the AJ27 has never been well supported, as far as I can tell, by the tuning companies. Two possible reasons are:
- it’s not so easy to analyze
- there was never enough business out there to justify supporting it
There is probably a bit of truth to both. As far as analysis goes, some of the challenges seem to be:
- Slightly obscure CPU – The Motorola HC16
- HC16 is not the easiest to analyze, since paged memory architecture requires knowing both the page and the address, which are stored separately
- HC16 variant (Y5 or Y6) used is not well documented – proprietary for Denso
- TPU2 module controls the injectors, but the TPU2 microcode (as far as I can tell) is Denso proprietary, not Motorola standard, so undocumented
- Dual CPU architecture adds complexity with shared RAM space to coordinate between the processors, and more complex reflash support – boot CPU1, load CPU1 boot code, boot CPU2, load CPU2 bootcode, reflash CPU1, reflash CPU2
- extracting the bootcode is fiddly, stopping either CPU results in hardware reset by loss of hardware watchdog to Denso power supply chip
- etc.
So, for no good reason, I’ve been poking into the code after pulling together various tools. If you want to do the same, you can find a Ghidra processor module for the HC16, a Ghidra loader for IDS .b68 flash files, and some key documentation at https://github.com/chirpy8. If you want a bit more info, read the posts at https://chirpy8.github.io/posts/
I’ve been focusing on XKR2002 flash files (F27SC074, etc.), so I have much much more info on that particular load. I will try and post more insights as I get around to it. Also I have coded a rough and ready benchtop reflash tool (since I was concerned that IDS would puke on a wrong checksum for a modded file – I now think it won’t for various reasons, but I find IDS annoying anyway), so I’ll try and post/share that at some point, once it’s more stable.
Since a little knowledge is a dangerous thing, this should help you on your way to modding your AJ27 and ruining your engine in no time at all :-) . I hope this is useful to someone, have fun.
Old Jul 7, 2024 | 09:32 AM
dfbender's Avatar
I have the same year and model so I (and others) I will be following your progress. 👍
Old Jul 10, 2024 | 04:27 PM
Chirpy's Avatar
Since there are a few more canbus extended PIDs (UDS service 0x22) that have showed up after analysis, compared to those listed in Dale's (crbass) spreadsheet (https://www.jaguarforums.com/forum/x...d-list-233056/),
attached is a quick summary. I did not attempt to merge into the original, but obviously that could be done.
Old Jul 12, 2024 | 03:58 PM
tlindi's Avatar
Originally Posted by Chirpy
Our AJ27 ECU design is now about 25 years old, and .... I hope this is useful to someone, have fun.
Wanna try to poke it with WDS on Engineering mode
Old Feb 16, 2025 | 03:33 PM
Chirpy's Avatar
I created an ECU re-flash/cloning tool, and a patching script, for anyone who wants to use a spare ECU to clone their existing unit (all AJ27 ECUs appear to be the same hardware) and tinker with mods. Still a work in progress, but seems to work so far….
Details at the website posted earlier.
Old Feb 17, 2025 | 06:48 AM
Adriantj's Avatar
An_Introduction_to_the_HC16_
This might help the process.
Wildcat_nl
May 22, 2022 11:18 AM
elDariusVargas
Jan 2, 2022 06:22 PM
mazzerman
Jul 25, 2021 05:13 AM
florin
Nov 21, 2014 03:38 PM
stanjag
Nov 1, 2012 08:24 AM
