Antenna fuse?
Old Oct 12, 2013 | 02:24 PM
Windycityx's Avatar
Originally Posted by XKRacer
Rather than cut wires...... Just pull the plug..... Easy to get to
What plug? I know pulling the fuse doesn't work with the premium sound factory upgrade.
Old Oct 12, 2013 | 06:44 PM
XKRacer's Avatar
There is a white plug that goes into the antenna motor, just unplug it
Old Oct 12, 2013 | 06:58 PM
Windycityx's Avatar
Where is this white plug located? In the trunk behind the carpet on CD changer side?
Old Oct 14, 2013 | 10:58 PM
Windycityx's Avatar
Does anyone know where this plug is located?
Old Oct 15, 2013 | 01:15 AM
XKRacer's Avatar
I did tell you but to be more precise.... Look behind the carpet where the antenna is, you will see the antenna and the motor attached to it, look for the wires going to it, the white plug goes directly into it
Old Aug 25, 2014 | 06:45 PM
Jimincalif's Avatar
Default Thanks to Roy
I just took Roy's suggestion and pulled fuse #9, disconnecting the power to the antenna. Wow is it ever nice to not have the antenna come up when using the CD, cassette, or ipod through the cassette adaptor. I also found that I have no trouble picking up the local FM stations I like, without the antenna. I am sure if I was going across country it would not work well, but then I would probably be using CD's or the ipod.
oldjaglover
Dec 25, 2024 04:33 PM
aode06
Jul 28, 2023 02:26 PM
philwarner
Jan 31, 2016 09:36 AM
goingjag
Sep 30, 2015 09:27 PM
