any ideas ?
Old May 16, 2010 | 11:26 AM
grazza's Avatar
Default any ideas ?
i have an xk8 2005 convertible - i suspect that the 2 read quarter windows are not resetting correctly after the roof is closed, as i am convinced that when driving the amount of wind rush / noise is loader than normal. Is this possible and how can i re set the these windows ?
all help appreciated
thanks
Old May 16, 2010 | 11:48 AM
test point's Avatar
They are adjustable but not resetable.
Old May 16, 2010 | 07:52 PM
attaboy's Avatar
Could you elaborate just a little .. how does one adjust? The "button down" for 5 seconds made it better, but still a little "weepy" on the left side. Seems the rain last week didn't get in, but I still see a little light.
Old May 16, 2010 | 08:03 PM
test point's Avatar
The door window range is reset with the down/hold, up/hold method you refer to. Beyond that both the door windows and the rear quarter windows can be adjusted by removing the interior trim and loosening bolts and moving the window regulator and re tightening.
Old May 16, 2010 | 09:08 PM
H20boy's Avatar
Hey guys, I'm drafting (as we speak) a thread explaining how to adjust your door windows, so it seals better against the rear 1/4 glass. There's a ton of adjustments...sit tight, and its got some DIY instructions with lots of pics to help you out. I'll need a few more days to finish it, I'm extracting some JTIS pages and intermixing my own instructions and photos with it.
Don't worry about the rear 1/4 glass, the adjustments of the door glass will seal it right up.
Harry Dredge
Oct 4, 2024 05:37 PM
Razor
Aug 28, 2019 08:34 PM
49Markvman
E type ( XK-E )
Sep 21, 2015 06:26 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
rachelstr
Sep 3, 2015 12:59 PM
