Apple connection cable
Old Aug 27, 2024 | 11:58 AM
Czechbikr's Avatar
Default Apple connection cable
When I got my XKR a couple of weeks ago I found this cable snaking out of the console cubby and recognize it as an Apple charge/connect plug. Because it looks so amateur of an installation I assumed it was done aftermarket by a prior owner but now learn from this great forum that it is OEM wiring. 😳
I'm an Android guy through and through so I want to link to the vehicle and have seen that there's devices to translate the connection from Apple to Droid. I know that the plug on the white end is not the 30 PIN connection. Do I pull the white cord from the black one in order to connect the adapter? I've tugged on that connection and it's really tight. Does it separate with more force?
Lastly, what connector/adapter is best for the application. Any links to products are appreciated and I thank you!
Old Aug 28, 2024 | 03:01 AM
dibbit's Avatar
That isn't an OEM installation, it is, as you first thought, an aftermarket add on. You'll have to take it all apart to find out what it is and if you can use it with your Android device.
Old Aug 28, 2024 | 06:33 AM
bladerunner919's Avatar
What cupholders are those?
In fact, what car is this? Is it anX100 or an X150?
Old Aug 28, 2024 | 09:02 AM
Czechbikr's Avatar
It's an X150 I believe.. not a fan of the cupholder either. Their only good feature is that it's removable for cleaning, the weird is each side is a different diameter. I suppose if I still drank, the driver side would hold a 12 oz Old Style. 😳
Old Aug 28, 2024 | 09:22 AM
giandanielxk8's Avatar
OP you posted in the wrong section. Your car is an aluminum bodied X150 XK, and you posted in the steel-bodied X100 XK8 section.
The following link will take you to the forum section that is pertinent to your car: https://www.jaguarforums.com/forum/xk-xkr-x150-33/
Old Aug 28, 2024 | 09:55 AM
Czechbikr's Avatar
Thanks, newbie error. Mea Culpa
vacolorito
Oct 14, 2022 05:03 PM
razorboy
Jan 13, 2022 01:17 PM
Michaell
Jul 6, 2017 10:27 AM
rlentini
Oct 27, 2015 03:40 PM
emaraszek
Jun 7, 2013 12:55 PM
