Auto Dimming Rearview Mirror Replacement
Old Mar 29, 2014 | 08:26 PM
  #181
Dalemeyer's Avatar
Thank you to batroute for the research on the Acura mirror. I was a bit skeptical so I did some internet searching and I found the Acura mirror to be a close match as best I could tell. I ordered one including shipping at $96. I received it and installed it, It fits and works like a champ. Wiring: black to black, grey to grey and pink to white. Both connectors come apart easily with a little patience.
Again Thank You.
Old Apr 14, 2014 | 07:31 PM
  #182
ErnestBrant's Avatar
Default Replaced Rear View Mirror
I've had an almost flawless run on my 2002 xk8 for the past four years. The only problem was that the rear view mirror retaining ring/adjustment ball had deteriorated and would no longer hold its position. A temporary fix of some adhesive left the mirror in a fixed position. After reading this forum, downloading the photos I purchased a replacement on Ebay and finally got up the nerve to tackle the install.
I took the advice of others and took my time. Sprayed wd40 over a period of several hours and lightly tapped with a screw driver. One push down as advised and the mirror was off. New one installed in reverse. Total work time: 30 minutes.
Many thanks to all who advised on this project.
Old Apr 25, 2014 | 05:56 PM
  #183
fitty066's Avatar
Default Free Mirror Install at Auto-Glass Place
Great thread! Same issue on my '99 XK8. Got a replacement mirror online but didn't feel very comfortable trying this myself after seeing quite a few broken windshield reports. So I called my local location of an auto-glass chain and they said they'd be happy to change it for me for free.
They did warn me they could break the windshield in the process but I felt like that was less likely than me doing it. So I took it over and in about 30 minutes I was good to go with no charge!
Old Apr 25, 2014 | 10:55 PM
  #184
aode06's Avatar
My replacement was easy, just through the old mirror in the trash,taped and tucked the wires in the headrest. Much better look.
Old Apr 26, 2014 | 09:49 AM
  #185
MFoncerrada8's Avatar
"What's behind you doesn't matter" Enzo
Old Jul 7, 2014 | 10:01 PM
  #186
rui's Avatar
rui
Default Replacement rear view Mirror
hi all,
I am located in Japan and I've contacted both Sybesmas and Radar-mirror but so expensive for oversea ($144 +shipping)
My xk8 (97) has 4 wires but uses 8pin plug(gray).
been looking at 2nd hand ones on ebay but 4wires on 8pin plug are hard to come by...
It would be great if I can buy spare off someone here or good suggestion for me. (I am planning to visit UK in a month time so could collect the item then?)
regards
Attached Thumbnails Auto Dimming Rearview Mirror Replacement-20140629_170109.jpg   Auto Dimming Rearview Mirror Replacement-20140629_170119.jpg
Old Jul 8, 2014 | 12:52 AM
  #187
grandell's Avatar
Have you checked the Yahoo auctions page? I know of a couple of XJ's being wrecked on there at the moment, the mirrors from those might fit, but with a bit of luck you might be able to find an XK one
Old Jul 8, 2014 | 07:57 PM
  #188
rui's Avatar
rui
Yes I have(I believe yahoo auction for Japan?), They do have those parts but they charge 30000JPY which is like just short of $300!!
so that's a no no for me. I did however found jag salvage yard in UK which i'm planning to visit next month!
Old Jul 22, 2014 | 02:56 PM
  #189
MarcisW's Avatar
Thanks for this write up!
While my mirror is fine so far, the black split ring that goes on the mirror (over the pivot ball) popped loose. The previous owner said it (the mirror) would have to be replaced. However, looking at it today, I do not see anything broken, so I will attempt to remove the mirror and reinstall the split ring.
Right now, the mirror just flops around on the pivot ball, and is very annoying.
Old Nov 19, 2014 | 10:36 PM
  #190
Grogers2033's Avatar
Thanks for write up on what to do. sent in Nov 12 and received back nov 19 an installed in 5 minutes. Flawless procedures. Total cost including shipping $97.
Old Nov 20, 2014 | 09:11 AM
  #191
aode06's Avatar
I confess, I just put a regular mirror, manual dim flip switch up in old xk8 for like $22 bucks. I used dental floss to remove the old mount, before scuffing the residue off with water and blade.
The wiring harness was neatly tucked away in the headliner, looked factory!
Old Dec 7, 2014 | 10:38 AM
  #192
walkman1's Avatar
My email from Sybesmas said the repair will not include the auto-dim feature.
Old Dec 8, 2014 | 07:27 AM
  #193
scottrader1's Avatar
Default non dimming
if they say that it won't dim, then maybe sybesma is finished with that, might as well get a plain ole cheap mirror for 20 bucks.
Old Dec 9, 2014 | 07:29 AM
  #194
walkman1's Avatar
Default Sybesmas
Stacy at Sybesmas says the auto-dimming feature should work after their fix.
Old Dec 10, 2014 | 10:39 AM
  #195
P700Dee's Avatar
Originally Posted by rui
hi all,
regards
I got a second hand mirror from a later car with a different plug but with a broken mount. I was able to split my broken mirror and the newer one and just swap the mirror/electronics. The internal connections were the same. The extra plugs on the newer mirror are not for the mirror so no issue changing over
Old
Newer
Mirror rear view
Old Dec 14, 2014 | 10:11 AM
  #196
walkman1's Avatar
Smile Mirror repair
Sybesmas fixed and returned my mirror in less than a week. It looks and works like new. Thanks to the forum members for the easy removal instructions. It's any easy job if you're careful and patient with the removal. Install is a breeze. I've done the ABS module and the mirror in the last month. I could not have completed either task without this forum.
Old Feb 3, 2015 | 12:34 AM
  #197
imagineaudio's Avatar
Crap. I dropped the torx head screw that holds the clip on to the pedestal, and suffice to say, it's gone forever.
Anyone have the specs on that screw?
Old Feb 8, 2015 | 03:06 PM
  #198
been to a couple of places now and still can't find a screw that fits...
anyone?
Old Apr 2, 2015 | 10:24 AM
  #199
Medic_186's Avatar
Default Rear View Mirror Wiring
I'm hoping someone can help me. My old mirror melted, and I got a replacement off of eBay. My old mirror has the yellow connector with lots of wires, and the new mirror has the blue connector with only 3 wires (black, brown, and a light brown/tan colored wire). Which of those wires connect to what wires on the yellow connector inside the overhead panel? I want to cut and splice into the old existing yellow connector.
Old Apr 3, 2015 | 03:44 AM
  #200
grandell's Avatar
Probably would've been easier to just get your one repaired through Sybesma...
but hopefully you can find the info about wiring you need here
JagRepair.com - Jaguar Repair Information Resource
