auto down /up stopped working
Old Sep 4, 2012 | 02:19 PM
Bigvettefreak's Avatar
Default auto down /up stopped working
I have a 1998 XK8. rag top.
The auto down when you open the doors on both sides just stopped working. they were working, now they go down but not up if you keep pilling the door handle, the window will go all the way down a little at a time, but will not go up when you close the door.
Could this be a fuse?
It is acting like my BMW now, everday it's something new to fix.
Old Sep 4, 2012 | 02:25 PM
Paul Pavlik's Avatar
Reset the Windows:
With the Door Closed, Lower the Window to the Bottom and hold the Switch for an additional 4 Seconds.
Raise and repeat for Window Up.
Repeat for other Door.
If this does not restore the Re-Seal function, your Battery may be weak.
Old Sep 4, 2012 | 04:35 PM
Originally Posted by Paul Pavlik
Reset the Windows:
BINGO!!!!!!!!!I did as you instructed and they work again!!!!!
Can't thank you enough.
Old Sep 10, 2012 | 11:31 AM
DewzeeXK8's Avatar
If battery is weak - due to leaving lights on - CAN YOU CHARGE BATTERY with a standard charge directly connected to the battery terminals?? or do you have to discionnect the battery ? I do not want to burn up any electrical parts before I fix all the existing issues -- Thanks in Advance. PS I have no owners' manual due to lame 1st owner
Old Sep 10, 2012 | 01:07 PM
Jag#4's Avatar
Always recommend charging disconnected, or even out of car on the bench.
If you go to sticky notes at top of main page there is now a full set of owners books, including the owners manual and service guide available for download.
JarodL
Mar 7, 2024 01:39 AM
tberg
Sep 7, 2015 07:32 AM
pnwrs2000
Sep 3, 2015 11:55 AM
XFR_Gold
Sep 2, 2015 12:24 PM
