Auto Headlight Diagnostic Advice
Old Mar 31, 2014 | 09:14 PM
PaulsXK8's Avatar
Default Auto Headlight Diagnostic Advice
Hi All. The auto-headlights on my XK8 have not been functional since before I bought it. My first question is whether or not there is a way to determine whether it is the headlight switch or light sensor in the mirror? The next question is, if it is the sensor, can that be replaced or repaired w/o replacing the whole mirror? For information, when I am rotating the light stalk, the first two settings work fine, and when I get to the auto setting there are no parking or main lights. I have also tried putting my finger over the sensor with the stalk in auto with no results. Thanks!
Old Apr 1, 2014 | 10:10 AM
batroute's Avatar
First thing to do is check that the mirror hasn't been replaced by a previous owner - he or she may have replaced it with a three wire mirror.Take off the dome lights and look at the connector - if five wires are coming out of the mirror then it does have an auto headlight function. Then check the wiring diagram on Gus's site applicable to your year - one of the wires carries the autoheadlamp signal - can't remember which one and I'm away from home at the moment. Try completing the circuit on the applicable wire(Check the schematic - not sure whether it grounds or goes live to complete - be careful). If the lights come on that points to the fault being in the electronic panel in the mirror. I'm not aware of anyone who repairs that circuitry - to my knowledge Sybesma do not.
You probably already know that the mirror sensor facing forward is the ambient light sensor - the rear facing one(i.e. towards the back of the car) senses lights behind the car. Out of interest is the mirror autodimming functional?
D.K
Dec 10, 2023 02:05 AM
VRB
Sep 15, 2015 08:18 AM
avern1
Sep 8, 2015 06:25 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
