Baby Got New Shoes
Old Jun 6, 2015 | 03:36 PM
Jandreu's Avatar
Default Baby Got New Shoes
Well I've been posting, asking questions and researching for several months about new rims for my 03 XK8. My factory staggered 19" Apollos are looking a little tired with the chrome pealing and curb rash from hell. So I finally pulled the trigger on new rims and tires. It was and adventure getting everything sorted out and I'll post full details shortly however for now tell me what you folks think, good and bad, I can take it.
By the way I absolutely LOVE the new look and feel the new rims give the car a more updated sporty look. A little mix of old and new school so give me your best shot!
There are photo's in the pdf files so I could make direct comparison of the old and new for your viewing pleasure.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 6, 2015 | 03:48 PM
ccfulton's Avatar
I like it. Sort of a classy muscle car look.
Old Jun 6, 2015 | 04:40 PM
jafari's Avatar
Very nice...
New wheels look mint and a 100 year improvement, but I'm not a fan of chrome finish anyway...
Mine are standard ones (I think they're called Luminas Jaguar XK8 Laminia Alloy Wheels 17 Ins | Jaguar XK8 and XKR Parts and Accessories) and have been tempted with an offer of wire wheels from a breaker yard for about $100 each.
Not sure yet, but saw some nice pics in a previous post: https://www.jaguarforums.com/forum/x...wheels-140125/
Enjoy!
Old Jun 6, 2015 | 04:49 PM
Jandreu's Avatar
OK, here's the details;
Rims are American Racing VN801 Daytona's - 18X9X24 4.75X5
Tires are Michelin Pilot Sport AS3 - 255-45-18
Lug nuts are from lugnutguys.com 1/2X20 spline. Regular lug nuts will not fit the rim as the lug nut hole on the rim is to small for a socket.
Center caps are from Welsh
pdf attached showing purchase details on all above.
The rims came with a 72.4 hub so I had them bored out. I found conflicting info on the hub size on the XK8, some indicated 74.1 and others 73.8. So I took one of my stock rims to the machine shop and had the hub measured, it was 73.8 so they increased the hub size on the new rims by 1.4 mm. Fit is perfect.
Also the rims have lug centric lug nut holes, cone shaped. So I ordered a new set of cone shaped lug nuts. As the new rims are 4.75X5 and the Jag is 120.6X5 it's close enough that there are no issues as long as the hub is sized correctly to make the rim hub centric.
I had the machine shop bore out the AR center caps to accept the Jag center caps and glued them in. The ones I bought are the cheap aftermarket caps and I may spring for the more expensive Jag caps later.
The tires I online ordered from Costco and cost $905 with shipping and mounting on the rims.
My 03 came with stock staggered 19's. 245-40-19 on the front and 255-40-19 on the rear. The front are 19X8X35 and the rear 19X9X33. The new rims are 18X9X24 running 255-45-18 tires all the way around. Now I can rotate the tires for better tread wear plus a little taller side wall for a better ride quality. See below pdf for the rim tire fitment comparison and you will see the new setup is almost an exact fit to replace the old setup. The new front sticks out .6" further and is .4" taller and the new rear sticks out .4" further and is an exact height match vs the old setup.
I've driven the car a few miles with the new setup and I'm very pleased, a little smoother and no vibration. Got it up to a little over 100mph and all is well with the handling.
Old Jun 6, 2015 | 04:51 PM
Jandreu's Avatar
jafari, Thanks and I like the wire rims also but new ones are out side of my budget. They do look sweet on the XK8/R though!
Old Jun 6, 2015 | 10:10 PM
Johnken's Avatar
I like the look! Nice job.
John
Old Jun 7, 2015 | 08:21 AM
K.Westra's Avatar
Love those wheels!!!! I'm pretty picky too Interestingly enough, I just put those exact tires on the rear of mine. I loved my Hankook Ventus V12, but I'm hoping to get more mileage out of these. I will do the fronts too when those wear out. The right rear was completely bald on the Hankook, and the Michelin will at least allow me to rotate side to side without having to dismount. Since you have the same size front to rear, you should get even better mileage than I do.
Old Jun 7, 2015 | 08:23 PM
Backyard Buddy's Avatar
Great pics!
Old Jun 8, 2015 | 04:48 AM
RaceDiagnostics's Avatar
Great choice and a very nice look.
Old Jun 8, 2015 | 09:39 AM
blindside's Avatar
A DEFINITE improvement over the chrome ones you had!
Old Jun 8, 2015 | 10:53 AM
tberg's Avatar
Those are great looking wheels, I have seen them on ebay and wondered how they could be so inexpensive and look so good. Great choice!
Old Jun 8, 2015 | 03:03 PM
max224's Avatar
Many thanks, as usual, to Jandreu who walked me through the morass of information on wheel fitment, bolt patterns, offsets, etc. when I was originally looking for new wheels, and a huge thank you to mrplow58, who already went the wire wheel route. I also have the Luminas on my car, and they look alright, but I thought that wires would look better. So I succumbed, and found a set of Dayton 17" wire wheels off of a 2000 XJ8 on ebay. They're getting mounted and balanced this Thursday, and I'll be posting pictures, (providing they all hold air).
You can get all a ton of information with the search term "wire wheels", which will bring up the most recent threads on the subject. Check out mrplow58's description of how he handled the wire wheel mounting and balancing. Good reading!
Old Jun 8, 2015 | 03:14 PM
michaelh's Avatar
IMHO you made a great switch. They have clean lines and look modern without being out of place.
I really like them, and they're much more in keeping with the car than the Christmas baubles.
Mike
Old Jun 8, 2015 | 08:32 PM
Jandreu's Avatar
Max224 I'm looking forward to seeing your wires. As much as I like my new rims I think wires are the sh*t.
Old Jun 11, 2015 | 08:19 PM
max224's Avatar
Turns out that the wheels turned out to be 16"s, not 17"'s. I'm really disappointed and not sure where to go from here. I would have to buy new tires to use the 16's and risk the issues that a different size wheel might create.
Old Jun 11, 2015 | 09:22 PM
Jandreu's Avatar
Compensate for the wheel size with the tire size. –16's are usable, play with the tire size calculator and find a 16" rim tire combo that is close to the 17" rim tire combo size. Down side is yes you will need to buy new. Tires but to have wires it may be worth it.
Old Jun 12, 2015 | 10:26 AM
max224's Avatar
Decided to stay with the wire wheels and get new tires (and tubes, if necessary). Been corresponding with Mike (mrplow58) who tackled the same project. I might need spacers so the wheels clear the disc brake cylinder (or grind them down like he did). Once again, the triumph of aesthetics over common sense!
Old Jun 16, 2015 | 03:42 PM
XxSlowpokexX's Avatar
Looks great!!...I bet if you lowered the car just a bit it would look even a bit better
Old Jun 16, 2015 | 06:04 PM
Jandreu's Avatar
I agree, never wanted to lower it until I swapped wheels. Reworked my front suspension a year ago but still unhappy with the handling. Looking at H&R sport springs with a 1.5" drop all the way around and new power flex bushings on the upper and lower control arms in front.
Old Jun 16, 2015 | 08:02 PM
PatB's Avatar
Sweet !
