Back-up warning system
Old Sep 16, 2015 | 10:44 PM
mhminnich's Avatar
Default Back-up warning system
When putting the car in reverse (2001 xkr), there is one long beep from the backup warning system but no further action from it. Sound familiar?
Old Sep 17, 2015 | 01:12 AM
Jandreu's Avatar
Nope, no difference in the back up sensors between XK8 and XKR, they only beep when an obstacle is detected. Sounds like yours has a fault.
Old Sep 17, 2015 | 03:54 AM
worrasf's Avatar
One or more of the sensors in the bumper will have failed. To test put in reverse with parking brake on and put your ear to each of the sensors - if working you will hear a faint ticking sound. I had this on my 2001 XKR a few years back and replaced a dud sensor. The 2 in the middle are easy to do the 2 on the sides are a PITA - they are also different sensor shapes.
Old Sep 17, 2015 | 08:54 AM
Stamford's Avatar
Some dope decided one of my backup sensors was a doorbell and pushed it in. I managed to get it almost back to normal but it is still a little recessed in the assembly, which causes constant false alarms. I've lived with it for a while because it is such a tight space to work in if you have human-size hands. Some day, I will bite the bullet and compete the fix. The backup system is a nice feature, but I still double check for obstacles, anyway.
Old Sep 17, 2015 | 10:10 AM
brgjag's Avatar
I think the system is kinda useless. I'd rather not have it honestly.
Old Sep 17, 2015 | 07:20 PM
Jandreu's Avatar
I couldn't live without it, I have reverse sensors and cameras on all my cars. If they didn't come with them I installed them.
The XK8 especially has bad blind spots to the rear and rear side, my sensors and reverse cameras have saved me several times.
Old Sep 17, 2015 | 08:02 PM
brgjag's Avatar
I think cars these days are making the driving public lazy and worse drivers.
Old Sep 17, 2015 | 09:32 PM
MediaBobNY's Avatar
The 05's/06's could use them up front as well due to the absurdly low air dam. Every time I park I have to watch out for curbs/parking barriers.
Old Sep 18, 2015 | 12:56 PM
Richxk8's Avatar
I had this same problem and found the connector on one of the sensors had come off, plugged it back on, problem solved. If it is not a connector then you most likely have a bad sensor or broken wire.
Old Sep 20, 2015 | 03:00 PM
JagRag's Avatar
Why oh why did I open this thread a couple of days ago?
Sure enough, today my car is now doing this...long beep when first put into reverse, then nothing as I back up. Had a very heavy & prolonged rainfall yesterday, could this be the cause? Time to check the sensors I guess.
Old Sep 21, 2015 | 07:53 PM
JagRag's Avatar
Well some good news today. My back-up warning issue resolved itself. Hopefully it was simply the heavy rain from the day before that caused the issue and it will not return.
Jpav27
Jul 31, 2022 06:43 AM
johndahlheimer
Sep 16, 2015 05:44 PM
fingers
Sep 11, 2015 12:21 PM
fingers
Sep 8, 2015 03:54 PM
AL NZ
Sep 4, 2015 08:39 PM
