Bad microswitch on passenger door
Old Aug 8, 2014 | 09:57 PM
mjlaris's Avatar
Default Bad microswitch on passenger door
Ok, so I'm back home after my big trip and my 2002 XKR has developed a couple of niggles. First, this happened just before I left on my trip, I have a bad microswitch on my passenger door. The window will move down when the door handle is operated but will then go back up as soon as the handle is released. I believe the part I need is Jaguar 97 98 99 00 01 02 XK8 Door Lock Actuator Right Passenger Tested | eBay. Would someone please confirm? Thanks,
Mark
Old Aug 8, 2014 | 10:42 PM
Jandreu's Avatar
That would be the part but the switch itself is very easy to replace and cost $5. I did mine with no issues and the door window works perfect every time.
Old Aug 8, 2014 | 10:43 PM
ccfulton's Avatar
Oh my no, if it is just the micro switch there is a much cheaper part:
C2N1908
Should be about $25 from the dealer.
The switch is kind of a pain to replace as it is a tight space but can be done in about an hour or so. Passenger side is easier than the driver, so that is something.
Old Aug 8, 2014 | 10:48 PM
Jandreu's Avatar
See this link, has links to instructions as well as where to buy the switch
https://www.jaguarforums.com/forum/x...oswitch-68735/
Old Aug 8, 2014 | 11:00 PM
mjlaris's Avatar
Great, thanks guys. I didn't think the micro switch could be bought by itself. I thought you had to buy the entire door handle mechanism.
Mark
Old Aug 8, 2014 | 11:54 PM
Jandreu's Avatar
See post number 6 here also for my wright up on the switch replacement
https://www.jaguarforums.com/forum/x...roject-118210/
kevinl
Oct 31, 2019 06:15 PM
PMKimpton
Aug 3, 2019 08:22 PM
UalCapt
Sep 14, 2015 01:42 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
