batt. charging 2000 XK8
Old Feb 11, 2016 | 12:56 PM
magnum454's Avatar
Default batt. charging 2000 XK8
Tried charging battery with cables connected and the alarm beeps. Disconnected neg. cable and seems OK. Could I have done some damage?
Haven't started car yet.
Old Feb 11, 2016 | 02:58 PM
RJ237's Avatar
If the ignition was on you definitely could have caused some damage. Even with it off that's risky. But you won't know until the battery is charged and you start the car.
I would not try to start it with the charger connected.
Old Feb 11, 2016 | 03:10 PM
magnum454's Avatar
The ignition was off.
Old Feb 12, 2016 | 06:05 AM
jamdmyers's Avatar
I wouldn't recommend charging a battery (in these cars) with the battery connected, just remove the ground. You'll need to reset your windows and radio codes if you not US which will take no more than 5 mins but may save some other electrical snafuu
Old Feb 12, 2016 | 10:22 AM
magnum454's Avatar
Thank all of u. Connected ground back on, all alarms went off. Unlocked with remote, alarms went off. Started it, reved pretty high then calmed down and all seems OK. Just wanted to ask you guys before I started it.
VR6Guru
US Western
Feb 22, 2021 02:39 PM
dsjohn
Feb 15, 2016 07:55 PM
AiJhae
Feb 10, 2016 10:40 AM
zidjan
Feb 9, 2016 03:04 AM
user 36297240813
Feb 6, 2016 10:19 AM
