BCM reprogramming
Old Sep 14, 2023 | 08:21 PM
Jagw1re's Avatar
Default BCM reprogramming
My ‘05 XKRs BCM burned out recently with no advance warning.. inside of the unit completely smoked.. ordered a replacement (same model number / part number) BCM accessories came back online but no ignition… I gather from the shop manual the instrument cluster sends a challenge to the BCM and the BCM has to respond to allow ignition to occur.. this suggests to me the BCM has to be reprogrammed so it has the same VIN as the car… can’t program it using my Autel or SDD .. jag canbus is supported after 2007. So what to do? Is there a way to bench reprogram a 2005 BCM? Can’t clone from the old one as it’s burned up. Thanks all :-) is there a place to download the old WDS from? And which pins on the BCM would I connect to.. so many questions… anyone out there with offer reprogramming services?
Old Sep 15, 2023 | 10:31 AM
xalty's Avatar
run immo setup my guy
bpm is not a programmable unit outside of the factory
Old Dec 12, 2024 | 05:07 PM
Pantera928's Avatar
Hello
I am having a BCM issue on an XKR also.
How did you ever resolve your issue?
Old Dec 16, 2024 | 05:56 PM
Tech_JLR's Avatar
What issues are you having?? I might be able to help.
BurgXK8
Sep 6, 2023 11:04 AM
cdma
Jul 23, 2022 12:54 AM
wforslund3
Jul 29, 2020 11:24 AM
jeje
Mar 19, 2020 12:49 PM
gloriashield
Feb 26, 2020 04:29 PM
