Block heater for X100
Old Aug 21, 2022 | 06:06 PM
CambridgeMart's Avatar
Default Block heater for X100
I'm in the UK but about to emigrate to Northern Finland; given that it gets down to -40C overnight in midwinter, I want to fit a block heater to the Jag. The car is a 96 XK8, it will be garaged eventually, but the weather may well get cold before my workshop renovations are finished, so it may have to stay outside for the first winter. I can't find a block heater for the XK8, although XJ8 heaters are available; any idea if the DEFA heater for the XJ8 would be suitable? It's.designed to screw into the block, presumably by removing a blanking plug from the cooling jacket.
Old Aug 21, 2022 | 07:03 PM
motorcarman's Avatar
Welcome to the forum but -40 is the ONLY temp that Centigrade or Fahrenheit needs no distinction.(Kelvin not considered)
Many parts for the X100 are NLA from the dealer but you might find a suitable replacement here from members that live in these extreme climes.
I live in Texas USA so I cannot comment on the need.
Good luck with the search for keeping the engine 'happy'.
Old Aug 21, 2022 | 07:29 PM
giandanielxk8's Avatar
I would imagine the XJ8 part should fit as it shares the engine with the XK8.
Old Aug 22, 2022 | 04:11 AM
tsuppari's Avatar
Greets, I do have Defa block heater w/part number DA411252 with additional wiring kits (DA460785 & DA460766) installed by previous owner.
DA411252 are listed as XJ8 compatible one here (in Finnish):
https://www.jussinmaki.net/ajoneuvoj...euvosopivuus-0
And welcome to winter hell
Old Aug 22, 2022 | 05:15 AM
Pistnbroke's Avatar
There were some available which went into the bottom hose ...tube with a heater in it ..cut and clip.
There seem to be stick-on sump heaters on ebay
Old Aug 22, 2022 | 05:27 PM
Yes, that's the one DEFA list for the XJ8 as are the cable and fitting kits. Thanks, I'll get that ordered.
RDMinor
Jan 2, 2019 08:19 PM
oyster
Jul 5, 2012 03:31 PM
Per
Nov 24, 2011 03:50 PM
ddasilva99
Feb 29, 2008 09:42 AM
