Bonet pull cable issue
Old Mar 12, 2025 | 02:02 AM
brinny's Avatar
I believe the bonet catch can be acssed by pushing the drain tube out under the wing and using that hole. Still a bit of fiddling
Old Mar 12, 2025 | 07:05 AM
Jon89's Avatar
When the hood release cable on my previous 2005 S-Type snapped a decade ago, I was able to open the hood by jacking up the front end, removing the front undertray, and reaching up with a long screwdriver to pop open the latch. That was on a rear-hinged hood. With the XK8/XKR being a front-hinged hood, this approach would be much more difficult if not impossible....
Old Mar 12, 2025 | 12:37 PM
Kuddlesworth's Avatar
I think you are only able to do it if you drill a hole in the wheel arch. At least that was what I have been told. The rear boot is similar although you need to take out the headlight and go in that way with a very long screw driver. It's not a very good time by the sounds of it.
DB48
Mark V - X 420G
Apr 5, 2024 09:34 PM
Andwell
Jun 26, 2021 05:35 AM
kennyjd
Mar 19, 2016 03:06 AM
wrd0225
Mar 6, 2014 10:35 AM
lostpinky
Oct 7, 2010 08:02 PM
