Boot (trunk) lights
Old Nov 23, 2015 | 12:39 PM
Mike76's Avatar
Default Boot (trunk) lights
Can anyone help when I open the boot the lights fail to come on. I have checked both bulbs and they are OK.
Old Nov 23, 2015 | 01:23 PM
DevonDavid's Avatar
Not a silly question ...................... does the glove compartment light work OK ??
Old Nov 23, 2015 | 02:28 PM
avern1's Avatar
The boot lights aare control by a micro switch in the locking mechanism. Do and advanced search for boot light and you will find some good write ups on dis-assembly and repair of the switch.
In most case after you open it up a good cleaning is all it needs. If you remove the trim around the latch I think the switch is mounted to the lock mechanism side.
Old Nov 25, 2015 | 01:56 AM
Mike76's Avatar
Thanks Devon the glove box light does work OK
Old Nov 25, 2015 | 01:59 AM
Mike76's Avatar
Thanks Avern will follow up on your advice.
Old Nov 25, 2015 | 04:17 AM
DevonDavid's Avatar
+1 on Avern's advice. Glove compartment and boot lights are on the same circuit, so microswitch is most likely culprit.
Winston Gilbert
Feb 11, 2016 02:32 PM
zach05855
Dec 9, 2015 05:26 PM
ramandanu
Dec 3, 2015 10:19 PM
zach05855
E type ( XK-E )
Nov 23, 2015 09:05 AM
essepi
Nov 20, 2015 09:43 AM
