Brake Booster Vacuum Pipe XK8
Old Sep 28, 2012 | 05:18 PM
khXK8's Avatar
Question Brake Booster Vacuum Pipe XK8
Just found a broken pipe that runs from the Brake Booster (Servo) to the throttle body induction elbow. The broken plastic pipe-end is still in the elbow, sticking out about 2cm. Anyone know how to remove this and where to obtain a new vacuum pipe for a XK8 1997.
Old Sep 28, 2012 | 05:46 PM
Is it Item 11 in this diagram?
If so, it's the Brake Vacuum Pipe - P/N MJA5910AC
Attached Thumbnails Brake Booster Vacuum Pipe XK8-xk8-brake-servo-vacuum-pipe.jpg
Old Sep 28, 2012 | 06:00 PM
khXK8's Avatar
Thank you for the reply. Its not this part of the pipe, there is a connector at the end of the pipe (11) in the diagram, and its the pipe that then runs to the throttle body and actually connects to the induction elbow. Do you have a Pt No, for this item please.
Old Sep 30, 2012 | 01:33 PM
khXK8's Avatar
Post Brake Booster Vacuum pipe
Resolved the broken pipe issue by having a new connector machined to fit the throttle body elbow. Then going to use a standard 9mm flexible pipe to connect back to the original broken vacuum pipe that runs back to the brake booster (servo) thank you for the booster diagram
Old Oct 1, 2012 | 09:45 AM
avern1's Avatar
I have the same problem on an XJ* booster line. Same part number. What kind of fitting did you have made. Pic?
Vern
97 XK8-Anthracite
98 XJ8- White
toronadomike
Jan 22, 2026 10:13 PM
clubairth1
30
Sep 3, 2025 04:38 PM
xjrjag
Oct 24, 2024 03:09 PM
mrplow58
Jan 21, 2024 05:53 AM
Razor
Aug 28, 2019 08:34 PM
