brake light cover on trunk
Old Jul 8, 2014 | 08:43 AM
tony bosco's Avatar
Cool brake light cover on trunk
forum, my cover to the brake light on the trunk is a bit loose (2001 xk8 conv.) is there a way to tighten. figured i'd ask before i brake it, i noticed theres 3 plugs in the trunk under the light but not sure if they have anything to do with the light it self or both the light and the cover ? tony
Old Jul 8, 2014 | 10:26 AM
vettegood's Avatar
Tony, the cover is a clip on, if it is loose chances are one of the clips is broken.
You can try epoxy to fix the clip or better yet I suggest getting some 3M 2 sided tape and taping it down.
A strip of tape from side to side on the back rear part of the cover will do the trick.
Good luck and remember
Happy motoring...
Old Jul 8, 2014 | 02:49 PM
Dr. D's Avatar
Howdy Folks:
Removing the 3 plugs in the trunk will reveal three metal studs/nuts that secure the brake light assy. If any of these studs have rusted to the point that the studs spin, I suggest plunging stud with a die grinder to free the nut.
Once the assy is removed, there are 2 rectangular access holes to insert a flat blade screwdriver to release the cover (note that trying to prise the cover without removing the whole assy will result in breaking the u shaped clips molded into the cover)
I had thought of using a full length of 3M dbl sided tape but first I experimented with three 1" strips which proved to be more than sufficient (for over 1 year) and the full strip may well be too much if ever you need to prise off the cover later.
My comment is based own my personal experience and I am not saying that my way is the only way.
Old Jul 8, 2014 | 08:27 PM
tberg's Avatar
Mine actually fell off one day when I opened the trunk and unbeknownst to me it fell into the trunk. When I found it in there, I used 3M double sided tape to stick it on, and it's been at least 2 1/2 years without any problem.
Old Jul 8, 2014 | 09:18 PM
motorcarman's Avatar
Jaguar issued a TSB (417-04) for your car years ago.
Probably easier to use the double side tape.
bob gauff
File Type: pdf
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
