Brake light right side.
Old Apr 14, 2018 | 11:37 AM
Johnnywrench's Avatar
Default Brake light right side.
About every three days rear bulb failure message.Check rear and right brake bulb is out. Put ground on assembly and made sure things are good . the brake light still stops lighting just have to touch bulb and it works fine for about three days Any help would be great
Old Apr 14, 2018 | 01:00 PM
magnum454's Avatar
Put more tension on the internal contacts and use some dielectric grease.
Old Apr 14, 2018 | 01:16 PM
Smile Brake light right side.
Thank you for the info, will try extra tension and grease on terminals. Makes sense on tension and I never thought about the Dielectric grease on contacts. I will give an update in a few days. Thanks again.
Old Apr 24, 2018 | 10:14 AM
Smile Working fine.
Thank you Magnum454 . The brake lanp went out once and I used my pick to tighten up the socket on the right side and all is well now. It has been a week now so I just wanted to thank you for the help.Next I will fix the bulbs in the Radio and A/C control head. You guys gave me all the info on that so it should be a breeze.
yeldogt
Feb 28, 2018 08:12 PM
wukyone
Feb 26, 2018 09:12 PM
Greg in France
Feb 23, 2018 11:58 AM
lofc2909
Jan 20, 2018 06:47 AM
