brake lights inop but third brake light works - RESOLVED
Old Aug 11, 2014 | 10:35 PM
jimangle's Avatar
Default brake lights inop but third brake light works - RESOLVED
Hello,
I have a 2000 xkr coupe and driving to work I was told my main brake lights are out and the third light is the only one that works. I confirmed this. I did a search on this site and it looks like it may be the brake switch, but is the third light affected by this? I just want to fix the problem accuratley. I did not have a rear brake warning failure. I've had other rear light grounding issues in the past, but that has been corrected. Also, I tried look at the wiring diagrams but the work computers block the weblinks. I'm using my phone to post this message.
I appreciate the help! This is my daily driver and New Jersey will pull you over if you have a light that thinks it wants to go out.
2000 xkr coupe 122k miles
Last edited by GGG; Aug 12, 2014 at 06:57 PM. Reason: add RESOLVED to thread title
Old Aug 12, 2014 | 04:28 AM
I'd expect a failed Brake Switch to kill all the brake lights.
Here's the relevant graphic from the Electrical Guide as a JPG:
If this is unreadable, I can print and scan it for you.
Attached Thumbnails brake lights inop but third brake light works - RESOLVED-xk8-brake-lights.jpg
Old Aug 12, 2014 | 05:04 AM
DevonDavid's Avatar
Looks like the "high mounted" light is on a different fuse to the two "normal" lights - top two fuses in the trunk fuse box. Might be worth looking here first.
Cheers,
David.
Old Aug 12, 2014 | 06:47 AM
jamdmyers's Avatar
I also remember reading some threads on tail light grounds, do a search on it and you will find many members had to 'improve' the grounding in this area, I'm not sure if it would affect just brakes or all lights or a mix ? Let us know what you find.
oops, reading too early I see u've visited the grounding issue, maybe just double check anyway
Old Aug 12, 2014 | 02:58 PM
jimangle's Avatar
Thank you for the help! I looked at all fuses last night, nothing was blown, but I hope I missed it as it looks like it should be the 5 amp fuse they both share.
Thank you!
Jim
Old Aug 12, 2014 | 06:31 PM
jimangle's Avatar
5a fuse was blown, all is good now.
Again, Thank you!
Jim
Old Aug 12, 2014 | 07:00 PM
Jim,
Thanks for posting again with the explanation.
I've added 'RESOLVED' to your thread title to help others searching for a solution to this issue in future.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
kesslari
Aug 31, 2015 04:53 AM
Jandreu
Aug 29, 2015 07:31 PM
