Brake Line
Old Jan 1, 2016 | 10:24 AM
bustednuckle's Avatar
Default Brake Line
In my pursuit of good upgrades for my 1997 XK8 Convert I ran across this offer which I can't take advantage of as my car can't be out service this long. I thought I'd pass along the offer to those who could. Let me know if you do it and they can build out the lines. From what everything I've read our US spec cars have some differences and the UK spec lines need some sort of modifications.
Hopefully these end-up as weekend-able bolt-in deals. I'm garage poor at the moment.
> Thank you for your inquiry!
> Unfortunately, there are no specs available to us for your vehicle. When the
> specs are not available we do have a possible solution.
> Send us your original lines with the fittings attached. Extremely accurate
> measurements of how long the new lines need to be, especially if you've
> changed anything or plan to.
> Include all vehicle information IN the package you send to us.
> Tag each line-drivers side front, passenger side front, rear etc.
> Include all of your contact information; Name, Mailing Address, Phone, email
> address.
> Once we receive the lines we can then search for the correct fittings for
> your vehicle. We will not guess at this for safety reasons!
> If we can duplicate these lines for you, we will contact you with pricing
> information. If you decide to purchase, we will give you a 20% discount! We
> will need your credit card information and we can return your original lines
> to you.
> Our mailing address and a separate shipping address is below if you'd like
> to try this solution.
> Hope to hear from you soon, we would like to try and help you.
> Kind regards,
> Brandi
> Mailing/Priority FLAT Rate:
> Paragon Performance
> PO BOX 143
> Lake Arrowhead, CA 92352
Shipping/FEDEX or UPS:
> 25268 HWY 18
> Crestline, CA 92325
Toll Free: 800-270-0333
> Direct: 909-338-1616
> Fax: 877-471-0274
> Paragon Performance: Stainless Steel Braided PTFE Hose, SS Braided PTFE Hose, SS Tube Stub Assemblies, Heat Pump Hose, Fan Coil Hookup, Power Trim Hose, Biodiesel, Brake Lines, Fuel Lines, Silicone Hose
Old Jan 1, 2016 | 10:53 AM
Gus's Avatar
Gus
Why not take one line off and take it to a local hydraulic line shop and see if they can match the fittings if they are metric. The advantage is that it is local and once they know they have the fittings they can make them on location making the turnaround time shorter. Most all hydraulic shops have the braided lines in stock. Several NAPA stores make hoses if you have one near you.
scottyg
Jun 15, 2022 12:11 AM
andyzeg
Dec 17, 2015 03:13 AM
cyber3d
Dec 14, 2015 01:08 PM
thedugger1
Dec 13, 2015 07:16 PM
ToddL
Dec 9, 2015 12:43 PM
