Brake Position Sensor
Old Jan 15, 2022 | 01:12 PM
Skipr's Avatar
Default Brake Position Sensor
My 1998 XK8 brake lights do not work every time the pedal is pressed. There also seems to be a connection with the solenoid that releases the shift lever from Park. May be connected to speed control as well. Are there other functions connected? Is a new switch warranted or is there some adjustment?
Old Jan 15, 2022 | 06:33 PM
RJ237's Avatar
One of the two micro switches in the brake switch is probably failing. They can be replaced at a fraction of the cost of the OEM switch. I don't have the information at hand, but if you do a search you should be able to source them.
Old Jan 16, 2022 | 05:41 AM
Jon89's Avatar
Yep, install two new better-quality microswitches into your existing brake pedal switch assembly. One source for new microswitches is www.mouser.com....
Old Jan 16, 2022 | 07:14 AM
Skipr's Avatar
Thanks. Will check it out.
scarbro2011
Aug 14, 2020 09:32 AM
anthawk
Jan 28, 2017 04:29 PM
Pier Paolo
Dec 5, 2016 06:57 PM
Kindlife
Nov 23, 2015 06:58 AM
jaguar lover
US Central
May 12, 2013 09:12 PM
