Brake Switch?
Old Jan 31, 2015 | 07:55 AM
Crushercurtis's Avatar
Default Brake Switch?
xk8 coupe.
Before I buy the brake switch, I what to make sure that's my issue.
When the car is first started the dash is clear of warnings. The cruise control button on the console will illuminate. After a few minutes I get a engine fail safe warning and a check rear lights warning. The car still drives fine and rear lights still work, but the cruise button no longer illuminates on the console. The cruise control definitely won't work after the warning, and I cannot confirm if it will work before (warning comes on before I get to the highway). I do not get a cruise failure warning at any time.
Old Jan 31, 2015 | 08:31 AM
test point's Avatar
Although the brake switch is a likely villain I diagnosed the same problem on my car as the cruise control switch. I would get these messages whenever the cruise button was up, never when it was down.
Exercised the CC button a lot of times and the problem went away. The plan was to remove the CC switch and spray with electrical contact cleaner but the problem has not reappeared in several months.
That might also be a plan for the brake switch JIC.
Old Jan 31, 2015 | 10:26 AM
Where can I find the brake switch priced reasonable?
Old Jan 31, 2015 | 04:50 PM
test point's Avatar
Reasonable? You want a reasonably priced Jaguar part?
I have to confess that I would take it apart clean and reinstall mine before I would spend $140+ on a new one.
I would try soaking the interior of the switch with electronic contact cleaner in place first.
Old Jan 31, 2015 | 05:08 PM
stevee D's Avatar
Default brake light switch
I had the same problem with my brake light switch. Went to a u pull, you save junkyard and found a switch in a older model jag. pulled it out and found the only difference was the pigtail on the switch. switched the pigtail with a solder iron and the problem was solved for $5.00. There are two micro switches in the brake light assem. One of which will probably be the cause of the problem. Easy enough to check with an ohm meter and I bet a micro switch can be found at radio shack. Good luck. steve
Old Jan 31, 2015 | 05:15 PM
try forum sponsor SNG Barratt, Jagbits or British Recycler's also 707autoparts.com has a few xk8's being dismantled
Forcedair1
Sep 8, 2025 01:57 PM
Rivguy
Nov 13, 2022 02:55 AM
flyrr100
Mar 14, 2016 06:37 AM
1964Daimler
Sep 9, 2015 11:28 AM
laserguy
Sep 3, 2015 02:02 PM
