Brake switch replacement
Old Feb 4, 2013 | 10:57 AM
randyb's Avatar
Default Brake switch replacement
Has anybody ever unbolted the switch from the bracket and then replaced or do you have to replace them together?
I see where I can get to the 2 bolts that hold the swich to the bracket MUCH easier than I can get to the bracket nuts.
Old Feb 4, 2013 | 11:04 AM
BlackX300VDP's Avatar
A genuine switch has the bracket already on it so, yes, you would undo the two nuts on top of the brake pedal tower. You may need a hand when putting it back together to line up the holes. ALSO, make sure the brake pedal is pressed down when you are installing the switch and do not release it until the nuts are tight. Only once I got lucky installing it alone, every other time I needed someone to guide the studs through the holes.
Old Feb 4, 2013 | 12:34 PM
Jon89's Avatar
There are several very good threads here in the XK8 section that offer great tips on both ways to replace the brake pedal switch - a new switch & bracket assembly as well as just a new switch with the original bracket left in place. It would be worth your time to search for them and read them....
Old Feb 4, 2013 | 01:38 PM
randyb's Avatar
I did not see one where someone left the bracket and just replaced the switch, but I will look again.
Old Feb 4, 2013 | 01:53 PM
jag18y's Avatar
hi any one know what fault code p1316 means, iv stuck it on hear as i dont know how to post it sepretley cheers
Old Feb 4, 2013 | 02:24 PM
Jag#4's Avatar
Randy,
Try this link to Gus' site. Scroll to the bottom and he shows how it could be left on the bracket.
JagRepair.com - Jaguar Repair Information Resource
Good Luck!
BrentGardner
29
Dec 16, 2024 12:13 AM
ronald4313jm
Aug 31, 2015 07:58 AM
kesslari
Aug 31, 2015 04:53 AM
roumor
Aug 28, 2015 01:02 PM
larney
Aug 27, 2015 07:54 PM
