Brake Switch Symptoms?
My XKR was already displaying the Check Rear Lights and Cruise Control not available amber light warnings before I changed the shifter trim for the aluminum one and had to realign the shifter cable. However, it now makes the Not In Park beep upon removing the key even though the car is in fact in park.
Can a bad brake switch cause the the Not In Park beep while simultaneously not allowing you to shift out of park until you use the overide switch?
I'm making a separate thread for this because I asked this in another thread, but it seems to be getting ignored.
You mean the light on P? That one lights up when the car is on Park. If you mean the dashboard Brake light, then that does not light up.
JagLawry
Nov 8, 2010 02:47 AM
JessN16
Sep 11, 2010 06:14 AM
GazUK
Feb 16, 2010 03:25 PM
