Break light on.
Old Sep 11, 2017 | 06:01 PM
Ken Scott's Avatar
Default Break light on.
Break light on. Was told it was sensor in break fluid reservoir. A different one didn't turn off light.
Old Sep 11, 2017 | 07:59 PM
clyons's Avatar
Welcome to the forum.
The brake light indicates the parking brake is not fully released. It could also be a bad switch in the pivot area of the brake lever.
Old Sep 11, 2017 | 11:07 PM
grantorino62's Avatar
When brakes "break" they stay broken!
Old Sep 15, 2017 | 02:30 AM
phanc60844's Avatar
if the brake light is on and its due to the handbrake, then you will get the handbrake warning if you try to move the car. I made the mistake of thinking an issue I had was the handbrake, but it was a throwback from an ABS issue (front left sensor). Once that was replaced, after 3 runs , it cleared itself. Torquepro will read the codes and tell you what it is.
