breather tool
Old May 5, 2014 | 08:23 AM
larueb's Avatar
Default breather tool
I am trying to remove the part load breather vacuum pipe from the sensor to clean it on a "99, located on left front valve cover. The diagram shows a clip to remove the pipe as it resists my efforts to squeeze and pull it off.
Does anyone know where to obtain this "clip"?
Thanks!
Old May 5, 2014 | 09:42 AM
bsprowls's Avatar
Got this from Gus's site that might help you:
http://www.jagrepair.com/images/TSB/...ings600-03.pdf
Old May 5, 2014 | 09:49 AM
WhiteXKR's Avatar
Thanks!
It should come off when you squeeze the knurled sections and pull. On old ones, sometimes the plastic gets deformed or cracked and making it difficult to remove. Sometimes a small screwdriver can help ease off the latches which are 90 degrees from the knurled sections while you squeeze and pull.
The latch is integral to the pipe and not available separately.
Old May 5, 2014 | 09:51 PM
motorcarman's Avatar
Jaguar did offer the clip release tool (special tool 303-623).
A TSB was issued in Feb 1998 (TSB 303-17) for info on the tool.
bob gauff
NathanDD6
Oct 6, 2015 11:20 AM
Johncy2000
Oct 2, 2015 01:05 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
rgp
Oct 1, 2015 02:55 AM
