Brittle Electrical Connectors!!!
I'm in the middle of tearing down the top-end of my motor to replace a blown head gasket. In the process of removing the electrical connectors to the coil packs and throttle body, several connectors fragmented under the mildest of pressure.
Am I stuck with replacing the entire harness or are there replacement connectors that I can swap out?
Many thanks in advance!
^^ What he said. I have also used small dabs of RTV to hold a couple of connectors together when their brittle attachment clips snapped off when I was doing the plastic coolant outlet duct replacement job on my wife's 2006 XK8 back in November 2014. No issues with them since....
I had the same issue with plastic connectors disintegrating. I found a business online Ballenger Motorsports that has a good selection. I was able to find the exact connectors I needed.
Thank you,RJ
The connectors I replaced were on a AJ27 throttle body. I did not have any part numbers but was able to visually recognize the replacements. One was the 4 pin connector to the pedal position sensor and the other the 2 pin power supply connector. The throttle body components are made by Denso and the connectors are common to Japanese manufacturers. If I recall the connectors on my car were also common on Toyota's .
https://www.ebay.com/itm/1-x-4-way-T...1/252828406104
The above link is to US eBay and i am pretty sure this is the 4 pin connector I used for the repair on my 2000 XK8 throttle body.
cincinnati
Apr 8, 2010 02:55 PM
