Broken Front Foglight Switch
Old Jun 10, 2014 | 09:01 AM
David's XKR's Avatar
Default Broken Front Foglight Switch
I took everything apart and found that the little black switch in the circuit board is broken. Has anyone dealt with this? Can I get just the switch and replace it in the board? If so any idea of a part number and source?
Old Jun 10, 2014 | 09:11 AM
jimbov8's Avatar
David, I would be surprised if you could get a spare to replace it with as it is on the board. You could try Radio Shack or your local salvage yards.
Old Jun 10, 2014 | 09:35 AM
WhiteXKR's Avatar
I did a quick search for the switch on a couple of electronic distributor sites and could not find a comparable switch. Your best bet may be a salvage unit: Jaguar XJ8 XK8 99 00 01 02 Fog Lamp Hazard Switch Dash Pack Part LJA 6292 | eBay
Still much cheaper than new: Jaguar Parts - Direct JPLV Porsche Parts.com
Old Jun 10, 2014 | 10:10 AM
The ebay ad says good through 2002. I called somewhere I've bought Jag parts before and they also said only good through 2002.
Old Jun 10, 2014 | 10:27 AM
WhiteXKR's Avatar
Comparing years on the electrical diagram, the connector and circuitry look identical. Physically the console stack had not changed. I think the backlight color shade may have changed from green to blueish green....but you can swap bulbs if necessary.
Old Jun 10, 2014 | 01:57 PM
I found a local electronics shop that works on TV's and such to look at it. I might swap the rear fog lamp switch. I never use it and he will do it for $20. But I think I might be able to find a switch, it looks generic enough.
Old Jun 11, 2014 | 08:18 AM
I was told that there's something to do with HID leveling that is different on the '06 module.
Old Jun 11, 2014 | 08:26 AM
WhiteXKR's Avatar
Here is a relatively cheap used unit: 1998 Jaguar XK8 Convertible Dash Mounted Power Switch Control Bank | eBay
One thought is to have your repair guy salvage a switch from this unit and use it to repair your unit.
Old Jun 11, 2014 | 09:26 AM
That would work, but I just hit the parts Jackpot. I found a shop a half hour drive that has a 2001 and 2004 XK8 for parts. Coventry West also confirmed that the books say 2003 -2006. They had one for $140 shipped, which I was all ready to buy but I digged a little longer and came up with this deal.
Old Jun 12, 2014 | 01:30 PM
[IMG][/IMG][IMG][IMG][/IMG][/IMG]I got the module and now everything is working fine. I got it from Eurosport Fine Automobiles in Cumming Ga. It's a great place that restores old XKE's and a lot more. Andy is the owner and he was very accommodating. They have a 2004 XK8 convertible with 30000 miles they are parting out and some parts left from a 10000 mile 2001 XK8 convertible. Here's his link esportauto.com. The parts cars are not mentioned but give him a call and he will work with you. The 2004 has a very nice black interior.
Attached Thumbnails Broken Front Foglight Switch-front.jpg   Broken Front Foglight Switch-back.jpg
Old Jun 12, 2014 | 01:32 PM
jimbov8's Avatar
Glad you got it sorted David and your cat is happy again.
Old Jun 12, 2014 | 02:12 PM
It feels good to have everything working. He also let me take the power antenna. Now I need to pull the seats apart to fix the head rests. And I need to replace the chrome rings on my 20's and...................
Old Jun 12, 2014 | 02:20 PM
jimbov8's Avatar
The antenna is an easy fix.
Check out Rev Sam's how to for the head rests, easy to follow step by step instructions.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
