burnt out light in the dash?
Old May 24, 2011 | 12:46 PM
Dalen's Avatar
Default burnt out light in the dash?
So, just recently my gauges began looking like this at night.
Is one of the lights behind the dash burnt out?
any suggestions?
Old May 24, 2011 | 01:05 PM
WhiteXKR's Avatar
You need to remove the instrument cluster and replace the bulbs:
See https://www.jaguarforums.com/forum/x...er-bulb-11423/. There is even a Rev. Sam video in that thread !
Old May 24, 2011 | 01:22 PM
Dalen's Avatar
Awesome thanks!
Old May 24, 2011 | 09:29 PM
Spurlee's Avatar
Default Bulbs
Also, no need to buy expensive Jaguar bulbs, they are pretty standard ones as you'll see when you get them out. One of mine wasn't burnt out, just needed to be reseated...
Old May 24, 2011 | 11:18 PM
Reverend Sam's Avatar
And don't buy the fancy LED bulbs. I bought them to replace my standard incandescent bulbs, but the LEDs really sucked. The cheap bulbs work the best.
Make sure you disconnect the battery AFTER lowering the steering wheel. Don't try to do it with the power on. I did that the first time and there was a nasty spark when I reconnected the connectors. Fortunately nothing was damaged.
Old May 25, 2011 | 09:29 AM
Spurlee's Avatar
Default Disconnect the battery
So did I and the same thing happened. There is a lot going on at that connection, don't give it any reason to act up.
Old May 25, 2011 | 10:40 AM
WhiteXKR's Avatar
+1000
On the XK8/R the instrument panel is literally the hub that links all the electronic modules together. You definitely want to handle it and its connections gently.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
JimMLiny
Sep 9, 2015 08:13 PM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
