Butterfly Valve
Old Jul 10, 2020 | 11:42 AM
YYC guy's Avatar
Default Butterfly Valve
Does the ignition need to be onto to open the butterfly valve fully or is purely mechanical from the throttle cable?
I tried to clean my throttle body yesterday and jammed a piece of dowel between the throttle pedal and the driver’s seat making sure to have the kickdown switch engaged with the ignition off.
The butterfly valve was only open about 1/4 of the way. The throttle cable had been adjusted to be taught and still allowing for the snap back to the stop when released manually.
Thanks,
Karl
Old Jul 10, 2020 | 12:49 PM
Just rotate the cable spindle by hand to open the butterfly for cleaning.
Removal of the TB is NOT required.
Old Jul 10, 2020 | 01:28 PM
motorcarman's Avatar
The throttle motor is pretty powerful. I would NOT mess with it while the key is ON (power applied).
Thoughts of missing fingers comes to mind.
bob
Old Jul 10, 2020 | 01:39 PM
YYC guy's Avatar
Default Butterfly valve
Both good points duly noted.
Thanks Guys
osyris
Aug 4, 2023 06:39 PM
H20boy
Sep 4, 2017 03:55 PM
Poet
Nov 22, 2016 10:33 AM
stevevaus
Sep 5, 2012 10:58 AM
XJR-0220
Nov 24, 2010 06:21 AM
