Calipers colour?
Old Oct 13, 2020 | 02:29 AM
slugger's Avatar
Default Calipers colour?
Have a -98 Xkr, standard brakes, calipers are in a gray metallic colour, and I have to touch up one of them due to a scratch messing with rear wheel bearing, anyone know of a good match colour code? Have tried google but came up with nothing
Cheers!
Old Oct 13, 2020 | 04:21 AM
powell's Avatar
I would paint all of them red
Old Oct 13, 2020 | 07:52 PM
NorXKR's Avatar
I don't think the grey metallic is factory. Mine are black and looks original (2000 XKR)
Old Oct 14, 2020 | 05:34 AM
I'd only ever seen rusty brown calipers on an XK8 before the days of Brembo. Have to go back to the early XJ6's and before for an OE black stove enamelled finish.
If the gray on yours is the same as the windscreen trim and door waist rail colour, this is Dorchester Gray.
BCS Automotive in Nottingham, UK can refurbish calipers or supply caliper paint in any colour for DIY refinishing. If the gray is an OE colour, they will know what it is:
https://www.bcs-automotive.co.uk/
Not cheap but I've always thought anyone who paints brake calipers can't be short of money.
Old Oct 15, 2020 | 01:48 PM
slugger's Avatar
Thanks all, I've now realised that I don't have standard brake calipers ......it is the brembo upgrade installed, car is new to me so dont have much knowledge of the XK models(confusing brembo upgrades with the RR upgrades that wasn't available untill 01/02(?), so yeah should make it easier to find a colour code with that info, here's some upgrade kit that are the same colour & brembo
https://www.autoreservejaguar.com/xk...t-upgrade.html
here is front left caliper(rear left still bubble wrapped to avoid further scratches since also doing the rear lower shock bushings once done with wheel bearing)
Cheers!
Old Oct 15, 2020 | 02:45 PM
Here's the OE Brembo on my 2005 XK8:
A much lighter shade and the "R" badging.
Old Oct 22, 2020 | 11:12 AM
slugger's Avatar
Looks like you havet the "RR" brakes, which is brembo (?), a newer incarnation of the ones i have i assume, and yes they do have all the shades brembo has ever made at BCS in UK, they are selling paint kits for diy'ers, about 40£(for 4 calipers), Will have to order before UK leaves the EU,
Cheers!
Old Jan 3, 2021 | 04:52 PM
dfbender's Avatar
Default Painted my XKR Calipers
Finally got around to painting the caliper on my XKR. After researching numerous caliper offing vendors and seeing what other forum members have done I decided on POR-15 Red. Very pleased with the results.
Results depend on following each step per POR-15 as specified. Very pleased.
Cleaned up the wheels too while I was at it.
Old Jan 5, 2021 | 08:51 AM
zray's Avatar
Originally Posted by dfbender
Finally got around to painting the caliper on my XKR. After researching numerous caliper offing vendors and seeing what other forum members have done I decided on POR-15 Red.......”
One must be very circumspect when painting calipers. Using 99% of all paints and even those labeled for caliper use, will result in degraded braking performance due to the paint holding in the heat generated by braking.
The best caliper restoration company uses a polymer coating that is only a few microns thick, yet has great protection qualities. In comparison, Home applied paint is many times thicker and does nothing to enhance the heat shedding .
http://www.goldlinebrakes.com/PolymerCoating.htm
Old Jan 6, 2021 | 09:18 AM
rothwell's Avatar
Interesting strategy painting the mounting red brackets to give the standard brakes a "larger" look. Don't remember seeing that before.
Not a fan of those OEM lugs though. Had enough problems with those for my lifetime.
patpayne
May 20, 2020 10:51 PM
Britrover
Feb 4, 2019 03:38 AM
Skeeter
Jul 17, 2013 05:57 AM
Frog
Apr 4, 2013 03:12 PM
cpm53
Oct 21, 2011 06:16 AM
