Cam chain tensioners or shock mounts?
Old Apr 4, 2015 | 08:26 PM
stetson1's Avatar
Default Cam chain tensioners or shock mounts?
Hey, I've managed to save a few hundred since getting my xk8 back on the road and have many in here to thank for their kind & generous help!
my '99 xk8 has 49k well kept miles on it and it runs & drives perfect. im the second owner and bought it from a very elderly gentleman who was unable to recall if he ever had the tensioners done, so I will assume they are the originals.
my shock mounts are deteriorated and want to change those out. my question is, which should I change FIRST, my tensioners or the shock mounts? my Michelins have less than 1k on them and do not want premature wear.
any advice is greatly appreciated, thanks,
frank in florida
Old Apr 4, 2015 | 08:29 PM
blindside's Avatar
Guaranteed EVERYONE will say to do the tensioners... and I agree. Better to lose your Michelins than your engine. Plus, I am not sure how much the bad shock mounts will contribute to tire wear...
Old Apr 4, 2015 | 08:43 PM
DaveInVA's Avatar
Tensioners of course. The new bushings won't do much good with a dead engine. The tensioners on my car originally failed at 57k miles and took out 2 exhaust valves.
Dave
Old Apr 4, 2015 | 08:56 PM
stetson1's Avatar
thanks! I kind of thought the tensioners would be most recommended, just wanted to make sure.
Old Apr 4, 2015 | 08:57 PM
stetson1's Avatar
thanks Dave! I too must save & scrimp every chance I get. fortunate to have ZERO bad habits. going to order the tensioners this evening.
Old Apr 4, 2015 | 09:15 PM
DaveInVA's Avatar
Christophers Foreign Auto Parts has by far the best prices. The kit with the chains, gaskets, tensioners and bolts is cheaper than buying everything but the chains separately even if you don't end up needing the chains. 99 is the year some have one type of cam cover gasket or the other so you need to check.
I've had very good experiences with this place.
Dave
Bcrary3
Feb 21, 2023 04:29 AM
picard
Oct 12, 2015 11:56 AM
looops
Sep 25, 2015 06:01 PM
Bowman
Sep 15, 2015 06:54 AM
davidladewig
Sep 11, 2015 06:48 PM
