Cam/Valve cover gasket?
Old Jan 23, 2012 | 08:15 PM
Fla Steve's Avatar
Default Cam/Valve cover gasket?
I replaced my cam cover gaskets with new "Genuine" Jag parts when I did the tensioners last year about 3,000 miles ago. Now the left rear is leaking again...dang-it. I read on the Forum that the following:
FEL-PRO Part # VS50724R $38.79 was a good replacement.
I've always trusted Fel-Pro they make good gaskets. However I just read, on the Forum, that the 3.9 Lincoln gasket is not the same.
Rockauto http://www.rockauto.com/catalog/x,ca...parttype,10710
this is for an 2001 Lincoln 3.9 LS
So what is the scoop, is it or is it not the same for the 4.0 Jag engine.
Old Jan 23, 2012 | 08:21 PM
WhiteXKR's Avatar
It is the same for the AJ27 4.0 liter engine, which is what you have in a 2000. '98 and earlier were the AJ26 engine and the gaskets are different.
Old Jan 23, 2012 | 08:33 PM
Fla Steve's Avatar
Default Thank you
Ah ha...thank you for the quick reply and answer. I will go ahead and order from Rock auto. WhiteXKR you are always helpful when I have questions...thank you again.
duecedriver
Dec 25, 2015 11:47 AM
Davidvdm
Oct 7, 2015 03:18 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
1964Daimler
Sep 9, 2015 11:20 AM
philwarner
Sep 6, 2015 11:10 PM
