Camber wear front tire question
Old Sep 20, 2022 | 08:15 PM
Johnken's Avatar
Default Camber wear front tire question
Hi guys, here's what's strange. Ride height is good, outer edge front tires wearing.
In the past I just replaced the upper shock mount. Where else can I look to fix this?
Thanks,
John
Old Sep 20, 2022 | 10:44 PM
Kuddlesworth's Avatar
Wheels probably need to be balenced, mine wore really bad on the inside and it turned out they where just out of balance a lot.
Old Sep 20, 2022 | 10:50 PM
baxtor's Avatar
Thanks,
John
How is your toe in setting?
Old Sep 21, 2022 | 12:20 AM
Pistnbroke's Avatar
Tracking is out ..they are running toe in so the outer edge rubs. You need to find the right figure and take it to a shop to have it adjusted . Usually the length of the track rod is in your case shortened. Check when you get it back that the steering wheel is still central in straight-ahead driving . Lazy shops only do one side
Old Sep 21, 2022 | 07:40 AM
Johnken's Avatar
Pstn, thanks mate!
Baxter, big thanks to you too!
John
RAWONE
Jul 15, 2021 10:39 AM
Johnken
Feb 26, 2019 09:20 PM
EZDriver
Oct 16, 2016 12:22 AM
jjf
Mar 18, 2016 09:24 PM
Wcsteam
May 5, 2013 12:23 PM
